Johnson 2 cyl 50 HP gearbox removal problem
kevinmitchell
having trouble removing the gearbox from my early johnson 2 cylinder ( 50 hp ). removed all the usual nuts and bolts and seperated but wont come off. seems the driveshaft and linkage are still attached but cant see when to dissconnect them. thought it would have just slipped off! can anyone help or advise me where i can pick up a manual? many thanks. kev
wilde1j
Re: Johnson 2 cyl 50 HP gearbox removal problem
Manual: outboardbooks.com
kevinmitchell
hi. thanks for the replies. it's a 1988, mod num J50TLCCS if that helps?? thanks
restornator
the shift linkage is on the bottom of the crankcase under the intake manifold. There should be a place to connect the shift rod
tashasdaddy
for novice it is easier, if you remove bottom carb.
kevinmitchell
removed lower carb and found linkage connection. gearbox now out, problem solved. many thanks for your help.
