brendantownsend
- Joined
- May 29, 2005
- 7
I have a Johnson Seahorse 4hp 2-stroke twin (1985 - Mod. no. BJ4BRC0B, s/no. B039078) and recently had the engine (ahem) "fully" serviced, though I took it out on the water and it died shortly after every time I increased the throttle. However, it would then pull-start straight up again, and then die on higher throttle, and so on.<br /><br />Suspecting fuel starvation I closely inspected inside the tank and found that the internal mesh filter had both corroded and broke away at the base, with other debris in the tank collecting around the only exit point left. I also found the elbow (linking tank to fuel line) so gummed up that it was incredible that fuel could pass at-all (I had to FILE this away with a needle file and repeatedly jet out the resulting plugs with carb cleaner!). I also replaced the perished and kinked fuel line, put in a proprietary in-line fuel filter, and all started up and runs OK without leaks. The morale of this story being that if you want it done "right" then do it yourself.<br /><br />However, continuing on this basis, I now want to set the mixture on the carb as it appears to be running rich (sooty/oily plug deposits and always runs best from cold without choke). Naturally I'll re-clean any residual debris from the carb beforehand.<br /><br />Incidentally, I am running with the recommended 100/1 fuel-mix ratio. I have a Seloc manual (#1302) but very confusing with the way it's presented as it tries to cover too much, and the carbs vary considerably between models and years.<br /><br />Does anyone have any experience with the carb fitted to my particular engine, that can give guidance to the adjustment procedure and location of the adjustment screws? I have ordered another manual though we're holidaying shortly and I'd like to sort it out as soon as possible.<br /><br />Many thanks in advance.
