johnson 20 hp slow idle
spycatcher
hi guys, can anyone tell me how to adjust the idle speed on my 1992 20 hp Johnson, thanks
jekuehl
Re: johnson 20 hp slow idle
Look at this link and notice part #15. That is your adjustment screw.
http://www.**********/parts/search/BRP/EVINRUDE/1992/E20EEND/CARBURETOR - 20/parts.html
Here are the steps.
Start by turning it all the way in, to the right and lightly seating it. Then back it out 1 1/4 turns to start with and fire it up and let it run for at least 30sec before adjusting either way in 1/4 turn increments allowing 30sec each time for the motor to catch up with the carb. Find the spot where your motor idles at its fastest and back it off 1/4 turn. Do this again on the water while in gear at its lowest idle to fine tune it.
spycatcher
hi jekuehl, that's great thanks
cant seem to get the link to work though
spycatcher
ok thanks for that, its a miserable day here at the moment, hopefully it will clear up later and i'll get out to the boat and have a go at it
cheers
aye it cleared up and so did the problem :) thanks for that, whatever did we do without the internet
many thanks jekuehl
