Re: Johnson 2003 150hp compression
Those big V6s were low compression engines. I would expect readings of 70 to 90psi, but I think you have a healthy engine and did something imperfect in testing. Throttle position is irrelevant, but engine temp is important. Look in the Top Secret File for a reliable compression testing procedure.
As boobie suggests, a decarb might make a difference.
