Re: Johnson 200hp slow to take off.
Yes, this is the first about an alarm....
But, if it were mine, I would look at the link and sync very carefully. It is a free inspection, and to describe it quick and dirty, from idle, as you advance the throttle, the timer base should rotate smoothly under the flywheel as you apply throttle to WOT. I am not suggesting you do this with the engine running. Do it with the engine off, and note the smooth movement of the timer base in relation to the throttle. The timer base should begin to move just a bit before the carbs start to open, so you have an advanced timing as the gas starts flowing, and the engine accelerates.
That is quick and dirty. The actual link and sync settings and adjustments are in the factory service manual, and it is an involved procedure. But you surely can look and inspect for free. Who knows, you may find a binding timer base that is stuck in dried grease that actually slowly finds the WOT position well after the linkage has travelled to WOT. Am I making sense? That might explain the lag, as well as many other factors.
