Re: Johnson 225 how high or how low??
Hi , Well thanks for the reply , first i need to take the engine off the boat because i need to do some work to it , the compression is very very low about 65psi on all cyl's , during the summer the oil injection unit failed and i didnt know until the engine stalled , the guy who owned the boat before me had disconnected the warning buzzer, this engine is a 1988 looper , the engine is still running , but its a nightmare to get started , when you get it up to temp its not too bad , but i have losted some power too , so over the next few weeks i'm going to do a complete rebuild , but i have loads off time its the winter over here in Ireland, i have another question too , the gearbox is not engaging in reverse at idle speed , its fine when you give it a quick burst off throtle in seems to drop in ok , has anyone come accross this problem , Steve
