I have a low speed adjustment knob on the end of the throttle/tiller. It doesn't seem to be working. I took the handle off and pieces of plastic exploded from the plastic start/shift indictor which used to be attached to the rest of the internal handle assembly by a metal ring. It obvious the internal handle parts are moving around because when I lift the tiller while the engine is idling the engine rpms increase slightly (like the low speed adjustment should). Is there anyway to fix this? I really need the low speed adjustment to work.
Thanks
Thanks
