daverowlands
- Joined
- Aug 29, 2007
- 24
Good day all,
Hoping to solve some problems with my engine as i'm new to outboards. First thing Its very smoky! I ran the engine first time out with some oil also in the fuel tank which the manual said you could do. Since then its been very smoky. 2 Stroke oil seems to drip down the casing after the engine has been stopped. No 2 Ran the engine again the other day with clean fuel, 99ron and it worked fine but after about an hour the engine seemed to mis a cylinder every few seconds, Could this be too much oil in the clyinder? Then i got home and tried to start engine to run fresh water though and it wouldn't start! cranks over but very weak. Also the engine check system doesn't work so not sure if this is related to the problems. Any ideas on this problems would be great
