I checked the compression, cold motor, I just pulled the spark plug wires and then pulled one plug at a time. I cranked it about 5 seconds, until it didn't go up anymore and I got about 138 on each one. Just need to know what it should be. If this is good then I have to figure out what might be next as far as not getting the power I had before. I may need to weigh the boat somehow to see if the foam is full of water even though I have left out the plugs for several weeks. It is an 18 foot Polar Skiff and I spoke with a guy from the company and he says he has only seen one boat with waterlogged foam so he doubts that is the problem and he claims the foam shouldn't hold water that the older boats had the wrong foam and a 96 year model should be good.
5string in NC
5string in NC
