I just found a 69 Johnson 4HP that looks a lot like an old lightwin. It starts first pull when warmed up and seems to idle and run fairly well. But it reads 50psi compression on both cylinders. I'm not positive my gauge is giving the full value but it's reading 50 on both cylinders (consistent). I checked the gauge on a chainsaw and it gave 110 psi. So it will go higher. It seems like WOT is a little jumpy but I'm not sure it's not because the load is going crazy in the can (water splashing out).
The lower plug showed some rust at the end of the plug threads near the electrode. I pulled the head gasket and it looks intact. I can still see some cross hatching on cylinders and there's no scoring.
Also, I can see that some of the reed valves are slightly open at rest. It can mis a little at medium speeds. I put a timing light on each plug and I think it's spark.
I'm curious if 50psi on both cylinders is ok.
