Muskyfisherman
- Joined
- Apr 13, 2012
- 3
I am new to this. In checking over my johnson 4 HP, found water in the lower case oil; took off lower unit, changed both seals and O ring. Vacuum and pressure tests were OK. When It came to putting the unit back together (water Pump)with the new empeller; I was unsure to put sealeant on the pump plate and the water pump housing. All the diagrams/manuals I can find to not list any gaskets and there is no mention of sealants on the housing or housing plate for the 4 HP, but the manuals do list use of sealants on smaller HP motors. When I took the water pump apart, there did not appear to be any sealant on the parts. It just seems to make sense to have a coat of sealant on the bottom and top of the housing plate, does that make sense?
