tbone303
- Joined
- Jun 24, 2011
- 84
This motor had been working perfect for almost 2 years, this summer when I took it out it would not idle for trolling. I know when the lower unit was redone that the main power head gasket had not been changed, noticed some oil slowly seaping from this gasket. I am thinking the powerhead gasket is the problem causing water in the cylinder resulting in poor idling, I can't even adjust the low speed needle for the motor to run smooth either. PSI was 75 in the top and bottom was 70PSI when cold, after running the motor for 10 minutes the psi on the top cylinder stayed the same but lower one was 62 PSI. Any thoughts?
