hi everyone, i just got my lower gearcase back from the dealer where i had the seals replaced, oil renewed and pressure tested. i put it all back on the motor and now in the neutral shift position it is in reverse gear, in forward shift position it is in neutral. forward gear is not possible. obviously i have not had any need to adjust my cables as the cable clamps were all that i had to undo to remove them. i have operated the shifter with the cables detached and it is obvious there is something wrong. within the series of linkages there is a detent ball with corresponding f/n/r notches and again in the neutral position with cables disconnected it is still in reverse gear. is there some adjustment of the shift rod within the lower gearcase that the dealer could have messed up or could he have put something back in the wrong order. i have to wait until monday now before i can strangle him! any advice much appreciated. many thanks in advance guys.
