FletcherJ50PL
- Joined
- Mar 22, 2010
- 2
Hi, Can anyone offer any advice?? I have recently boat a boat with the said engine and I am replacing my Power tilt unit as the current unit was badly corroded at the bottom around the release valve and check valve making it impossible to repair. It took me about a week of heating and hitting to release the bottom pin. I am now faced with trying to remove the top pin, which after 4 days of soaking, heating and hitting doesn't want to move. I even today bought a 7lb hammer for extra whack. I've been using penetrating oil, ammonia (i read this dissolves aluminium oxide). I've even drilled a hole through the left hand transom bracket in order get a drift to be ht square on to the end of the pin. ( This will be filled with metal putty as only the sender unit rests against the piece i've drilled through.)
Can anyone tell me why the top pin has an internal thread on right hand outside edge (the bit with the collar). Has anyone tried screwing a bolt into it to try and turn the pin - Is that what its for?? Any suggestions on removing the pin would be greatly appreciated. I'm afraid i'm going to miss our short English summer if I can't get it out. Please help with any advice.
Yours in desperation.
