johnson 50hp not charging battery
jtexas
Re: johnson 50hp not charging battery
Replace the rectifier.
Make sure the battery cables are good and connections are clean and tight. If you use wing nuts, tighten 'em with pliers. Loose battery connections (or running without a battery) will fry the rectifier.
Sorry havent replied i must have posted this twice, thanks for your help.
ROB
