Re: Johnson 55hp 1969 no spark when starter spins
Finaly finish my troubleshooting,here are the details maybe it would help somebody else.<br /><br />Problem, <br />No spark, or very intermittent, specificaly when using starter instead of manualy turning flyweel.<br /><br />Solution<br />Install Diode on power wire of CD unit as per Joe Reeves instructions, that has raised the available voltage to the CD unit, Install fresh battery group 27 marine. Replace lots of rooted wiring in the engine and under flyweell, on the points, clean and regap the points. Running very smooth now.<br /><br /><br />Problem:<br />Always on forward gears, no neutral or reverse<br /><br />Solution:<br />Test all the voltage on green and blue wire as per Joe's instruction, all OK.<br />Flush gear oil and refill to top with type C oil, tested work fine now.<br /><br />I thank you all again for your help on my issues, great site with great people.<br /><br />Freddy,<br />Johnson 55hp 1969, back to life !!!
