Johnson 5hp
Crosbyman
yes they will work ... get them while cheap
check compression before spending $$$$$ report back findings
change plug wires and boots while at it. use 7mm solid strand copper wire
local bike shops or small motor shops could sell a few feet to you
I have use basic metallic strand 7mm wires and that work to .
do not use carbon fiber wire
TN-25
A TN-28 (1952½-53) uses those coils and the regular automotive type breaker points. The older T-series, including the TD-10 & 20, plus TN-25 through TN-27 use the old guillotine style points.
Crosbyman
TN27 like the TN28 also uses the more "modern coils", points and condensers .
see Johnson manual page 29
Crosbyman
anytime you want to work on oldies the best book around is this one for $20 just download and print locally. save it on ypour PC hard drive. or laptop
dirt cheap 400 page + manual covering all aspects of your engine.
J& E are cousins and this Johnson book pretty well covers what you would need on an Evinrude cousin.
covers ignition ...carbs... gear case shifting neutral on some TN,s etc... etc..
