Johnson 6 1970
skilbo
I have a trickle of oil and water that comes out of a small hole in the leg just above and behind the oil fill hole. <br />Is this the overflow hole for the leg oil?<br /><br />This has been bugging me for a while and noone seems to be able to help?
ob
Re: Johnson 6 1970
Does it appear to be gear oil or black two cycle oil residue?Have you inspected the gearcase for water intrusion?Water in usually means oil out.
D
DJ
Guest
Re: Johnson 6 1970
skilbo,<br /><br />I think you are seeing exhaust residue.
skilbo
Re: Johnson 6 1970
I believe it is gear oil mixed with water so it's bubbly and creamy colored. I recently changed the leg gear oil and it was black (no water in it at all)
