snail pace
- Joined
- Mar 6, 2009
- 3
Hi everyone hope one of you guys can help. i am new to boating and have an issue with my Johnson 60 (1984) engine. i am not sure when the boat was last used so not sure if it has been stud. the engine runs on the hose pipe and goes into gear fine, but once lowered in to the sea it stalls when put in gear. I pulled the boat and took it home and placed it back on the hose where it run fine again. I have checked the Spark Plugs and they are fine i have also checked the compression 75psi on both cylinders. Not sure if this is relevent but when i had the carbs uncovered i ran the engine and covered one carb with my hand which was sucked into the carb and the engine then stalled. i started the engine again and covered the other carb and my hand this also was sucked in but the engine did not stall.
Can someone please shed any light on my problem as im really scratching my head. and worrying its going to cost me.
Cheers
ANDY
Cheers
ANDY
