Re: Johnson 60 Over charging?
Rectifier is just to convert AC to DC.. If it has a regulator/rectifier, it still may show 17 volts, but the amps may be very little. It will also put out what the battery demands, so you may want to check the batteries and condition, make sure they are healthy. A bad grond can cause high charge-rates too...
