Sonwatcher
- Joined
- Jun 12, 2004
- 32
I have a '66 Johnson 60. I cannot get it into Forward with the cable. At first I adjusted the cable and could get forward but no reverse. Then I adjusted the reverse on the cable and could not get forward. I disconnected the cable and manually it will adjust in forward and reverse. When connected the cable moves as it should but when I put the gear in forward and attach the cable I put it in Neutral and tried to go back to forward and reverse it wouldn't happen. The motor was running when I did this testing as well as doing it with the motor off and turning the prop.<br /><br />Any suggestions ? If it is the cable , with it working what would cause it to not be able to pull it in gear when it does go in gear manually?
