Have an old Johnson 63 3HP outboard engine that runs like a charm. Lately one of the ignition coils started to spark through a crack in the plastic cover of one of the ignition coils. Tricky to find since the "leakage" depended on temperature and RPM. (At a low RPM it run on one cylinder only)<br /><br />Once replaced - What is the best way to adjust the position of the ignition coils?<br /><br />What should be nominal air gap between the flywheel magnetic surface and the coils?<br /><br />With age the play of the crank shaft may affect both the coil air gap and the ignition contact points. How much play should be accepted?
