Alan_Scott
- Joined
- Nov 25, 2011
- 69
I picked this up yesterday and it would only idle with the choke on. I pulled the carb off and cleaned the sludge and varnish out of it and now it fires up and seem to run fine but it's been a long time since I've messed with a 2 stroke and the smoke seems excessive. The fuel is fresh with a 50:1 ratio of Pennzoil outboard oil.
Also, is there a thermostat in it? The heads were warm to the touch but the water coming out of the weep hole always felt stone cold. The water temp in the barrel was probably mid 30's.
I filmed this after it ran for just over an hour in gear at a high idle
http://www.youtube.com/watch?v=dcB4W996HCc&feature=youtu.be
