texas_salt
- Joined
- Apr 7, 2016
- 42
Whats up guys.
I recently restored a 6R-69M
-new plugs
-new wires
-new points (timed properly)
-new condensors
-new thermostat
-new lower oil
-rebuilt carb
-impeller in good shape
-50:1 gas/oil
Its on a 12ft semi V-Hull.
I've taken her out twice and shes running beautiful and reliable. Good/Fair spark on both cylinders.
EXCEPT, at WOT i'm only getting about 6-7MPH according to the GPS.
From my youtube research, I see guys easily doing 12-15mph on the same old motor. Now, i'm a big guy. 290lbs. So thats an obvious factor. Its also on a semi v-hull which I have read can play a role. Finally, and possibly the real culprit? compression is 60-70 PSI on both cylinders. Which I hear isn't great, but, eh.
So, knowing the above, does 6-7MPH at WOT sound about right? I just want to be sure i've ruled out anything mechanical.
-new plugs
-new wires
-new condensors
-new thermostat
-new lower oil
-rebuilt carb
-50:1 gas/oil
