I have a 1955 or so 7.5 Hp Johnson that ran fine, but needed a water pump. After replacing the water pump there was water pouring out the bottom of the tube that runs across both cylinders. Is this tube supposed to be plugged at the bottom like it is at the top with some sort of casting plug? If so the person that had it before must have dome something to lose that plug. Here is a pic of what I am taking about.
The bottom of that tube is open and water pours out.
