I have recently bought (with the boat) a Johnson 70 (1997) , however, after maybe 7 hours it threw a con rod !
??. Even though it was dealer serviced before my purchase
???I have spoken to the dealer but I would probably get more response from talking to a wall !
I have stripped the powerhead and the problem was due to water damage on No3 cylinder
and a good replacement powerhead has been sourced ???.. it is assumed that the boat took on rain water at its sea mooring which allowed the lower engine cowl to go below water level !.....I am guessing that all this happened to the last owner just before the boat came up for sale, and it was stood for 6 months before I purchased it???.. TBH the engine sounded very sweet right up until it threw the rod
???..so now you have the important history.
The document history shows the VRO pump (I assume VRO2) had been disconnected due to the engine smoking badly and the very same dealer had diagnosed the pump as having a suspected faulty oil diaphragm and delivering too much oil. It was changed to run on 50:1 premix and it ran OK.
I have looked at the manual and the VRO pump is controlled by pulses from No3 cylinder. As No3 would have had little or no compression and the inlet reed vales were rusted in the open position could this have caused the issues with the VRO pump oil delivery ?
When fitting the replacement powerhead I was thinking of going back to using the VRO ???. Or is premix a better option
