Hello all,
I am in the process of installing a new tach on my boat w/o any harness.
I opened up the control box to find the correct wires and found something that puzzles me. Right above the key ignition switch in the control box there is a little black electrical box. The box is approximately 1-1/2" wide by the same across. On the box, there is a "+" connection. It appeared to at one time have 2 purple wires connected to it on the positive side with a single brown wire coming off the other. Both purple wires and the brown wire have been disconnected and all 3 wires have their connections taped over with electrical tape.
Any thoughts as to what this is, why it may be disconnected and what may happen if I reconnect the wires?
I believe the purple may be ignition, but what did someone want to keep from operating and why?
Thank you for any help.
