Johnson 70hp bogs under acceleration
Notchcraft
I have a 1982 Johnson 70 that will start and idle fine. But about half the time when I accelerate it will want to bog. I noticed that if I "wiggle" the throttle back and forth when it happens it will take off and got to wot like it should. once on plane it will run fine, it only bogs when going from idle, if i'm at 1/4 throttle and slam it down it accelerates like it should.
I rebuilt the carbs, replaced the welch plugs
new gas
new spark plugs (look great)
compression is 120 on all three
Did a sync/link per 1982 OMC manual
Any ideas?
