Outboard has not been started in two years. I do not know any other history. Good compression of 136. Installed new water pump, new coils, new plugs. Engine started right up with choke and warm-up idle set. Ran smooth for 45 min with warm-up throdle, but would not run at lower idle. Plan on replacing fuel pump. What are the chances that carb needs a good cleaning? Is that a difficult task? What about low idle adjustments? It is a dual carb system. I know I need a manual. Any other advice is greatly appreciated. Thanks in advance, <br />Roger
