I have a johnson 1979 150. I am testing this out of the water with a hose connection. One bank does not seem to be working. I have check the spark at each spark plug and there is spark. One bank seems to be at normal temperature the other is cold. I have taken the carbs off an cleaned them. This is the same side that the control module was replaced early last year, not sure if that is a coinsidence or not. Had problems last year with going from an idle to fast. Also seemed to need a long warm up period. Would falter then get up and go. HELP HELP HELP.
