johnson 85hp 1060 dont start???????
sly36
Hi. i try to start my engine i put new plug clean carb and the engine dont want to start just make backfire i dont instal the lower unit i try to start the engine before i dont think they change something anyway someone have ideal???
sly36
Re: johnson 85hp 1060 dont start???????
no one have ideal ??? Please :)
Silvertip
Running the engine without the lower unit means it will have no water for cooling so you could do serious damage to it. Use a spray bottle to squirt a fuel/oil mix into the carb. If it starts you have a fuel delivery or carb problem. If not, you need to check compression and make sure you have good hot spark at all cylinders.
sly36
no i change nothing in the wire they only think i do its clean the carb and restore the boat paint and change seat and i try to start the engine but make some fire but dont want to start do you think its because the lower unit its not install???
sly36
Upinsmoke thank i know without lower unit no water cooling but i just want to start and close i will try what you said <br />Thank you!
sly36
i plub my radio, depth sounder and water pressurre gauge in the accessories wire of my boat switch i read in my book never connect accessories to key switch do you think thats my probleme to start my engine???
