johnson 85hp v4 1979
jimcrain1966
bought a used 1979 johnson85hp v4. how easily should I be able to turn flywheel by hand,with two hands.one hand or a few fingers?
Bosunsmate
Re: johnson 85hp v4 1979
two hands working hard with plugs in and a few fingers with plugs out (depending on how new the impeller is)
jimcrain1966
Why do you ask ??
battery is fully charged, starter engages flywheel but it takes 15 seconds for it to turn one revolution, and wont start.its been sitting for a year.will outside temp make it slow?
Bosunsmate
Only if it was so hot that the flywheel melted into the engine. I dont think you would be keen to go boating if it was that temperature outside.
Pull your plugs out and see if it makes any difference. It should be pretty easy by hand then too. If its not easy you have an engine problem.
I suspect you have a worn starter, solenoid, or cables.
Check its not the engine binding up first
