Johnson 88 SPL prop size?
slapshotjh
I have a 1989 Johnson 88 SPL. I purchased it used with an 18 foot Sea Pro center console. The boat is light, it has no options other than the console, no fuel tank other than 2 6 gallon portables. <br /><br />What propeller should I use for better fuel consumption and better top end. The prop on there now is stamped 13X19. I believe it was used for skiing. I don't have an owners manual to tell me what WOT should be.<br /><br />Right now 4000 rpm gets me about 26mph. the boat seems to top out at 31 mph at 4800-5000 rpm. Is this the correct set up, or should I expect more?<br /><br />Thanks,<br /><br />Jon
psdan000
Re: Johnson 88 SPL prop size?
sorry to bring up an old post, but I have nearly the same setup and would like to hear some input on this.
SparkieBoat
1st do not hijack a post..2nd there is a special forum just for prop questions..start a NEW post there and someone will be glad to help you...and welcome to iboats forums.
