Johnson 89 40 boggs but picks up when choked
CU2NITE
I have an 89 40 hp Johnson that boggs, but picks temporaraly when the chock button it pushed. Is this indicitive of a carb problem or a fuel pump?
Thank you
CU
RUNNING THE MOTOR WHILE LISTENING TO THE HORN WILL MAKE YOU MORN!! I KNOW I DID IT!
iwombat
Re: Johnson 89 40 boggs but picks up when choked
Carb problem. If it picks up, it's getting fuel.
That being said, make sure you don't have any air leaks and your connections are all tight. Could be that the choke is compensating for frothy fuel.
CU2NITE
Update-I rebuilt carbs and it runs like a champ. Anyone else out there that has a bogging problem and the motor picks up while holding the choke in, I would recomend a carb rebuild. Very easy, use lots of carb cleaner to clean internal parts when disasembled. Get a kit they are cheap.
CU
