i am tearing my hair out.
1989 j8rcec 8hp. overheating. i had good flow from pee hole, nothing from exhaust relief port in back of down tube except for a lot of steam when hot. inspection stream extremely hot.
-head and exhaust covers removed and all passages cleaned out as well as around cylinders.
-removed thermostat
-new water pump. grommet well seated on tube. (good flow from water tube when hosed through thermo port while disassembled.)
-when i hose water through thermostat housing with exhaust cover off, i get good flow from lower right passage in exhaust housing, somewhat less in lower left.
-when i run the engine with the thermo cover off, (exhaust cover obviously on) i get very little flow through the thermo port unless i put my hand over the below water exhaust port to force back pressure.
-engine fires right up and runs smooth but inspection stream still extremely hot and cylinder head extremely hot to touch after a few minutes. i have tried with hose hook up as well as on boat.
i just did the exact same routine on a virtually identical 1987 j6rcud with good results. i am out of ideas on this one.
what am i missing?
-removed thermostat
what am i missing?
