Johnson 8hp
eula30
Hi, I have a 1999 Johnson 8hp came with 2 propeller one is bigger than the other. I used this motor as a kicker. Witch propellers you guys think is best? The bigger one or the small one and does it really makes any difference?<br />Any help I will really appreciated.<br />Thank you
wayne h
Re: Johnson 8hp
run them both and see what does better on your boat usually the smaller prop will run at higher rpm's faster and give you more top end but it all depends on your setup
