Going to rebuild my motor this weekend. I bought a new block, pistons, and rings. I am going to replace the crankshaft oil seals as well. I know not to put gasket seal on the head gasket, that the crankshaft case uses gel-seal, and that I should use vaseline to put the needle bearings back on. The cylinders were recently honed so I plan to use brake cleaner to clean the engine and cylinders and I will use Automatic transmission fluid and lint-free towels to wipe out the cylinders and remove grit once clean. I also plan to use dish washing liquid to wash the needle bearings. I do not plan to put sealant around the crankshaft oil seals.
Is there anything I'm doing wrong or forgetting? Any tips / tricks before I begin? There are 3 piston rings (and I can't discern a difference in appearance between the three) - do they need to be installed in any particular order or manner (besides making sure the black stud is in the middle of the ring gap)?
