Johnson 9.9 to 15 , can this be correct?
one more cast
there is a mid 70's Johnson on 9.9 hp eBay that the seller says is now a 15 hp (just by putting a 15 hp carb on it)says this is the only differance between the 2. I find this hard to believe what do you experts say?<br /> Thanks, one more cast
Joe Reeves
Re: Johnson 9.9 to 15 , can this be correct?
That is the case with the eariler model 9.9hp OMC outboard engines. The later ones needed a couple other items changed, but still the carb alone would increase the power. Bottom line is that the statement is true.
AWWALKER
Joe, would this also apply to my old '62 Johnson Seahorse 10 ?
Joe Reeves
Walker.... No, sorry. It only applies to that 9.9hp model.
Allan19603hp
I am currently in a debate on a vacation and I dont have my shop books with me. I could be wrong but a 1986 Johnson 9.9 to swap to 15 you need to change more than the carb... Is this correct I have made the change with a 77 9.9 and there was a major difference.. If someone can supply me what needs changed so my friend can see. I can prove it to him in the books when I get home but I am 200 miles away from them... Someones help or advice especially Joe Reeves. or anyone would be great..<br /><br />Allan
