I have a 1989 Johnson 9.9 electric start. I was out on the water a couple of weeks ago and it was running fine and it just died. It hasn't run since. It looks to me like the spark is weak. If I pull the plugs and ground them, I do get some spark that appears to be blue. If I put a 1/4 inch bolt into the spark plug wire and crank the engine, I can jump a spark with no more than a 1/8 inch gap. Both cylinders are the same. Squirting starting fluid into the carb or the cylinders produces no fire.
Here's what I've done so far:
New plugs gapped at .030
Tested compression - 120 PSI on both cylinders.
Cleaned all visible wire connections.
Pulled the flywheel. Everything under there looks clean (and expensive). I'm pretty mechanically and technically savy. Are there any tests I can perform with a DMM or oscilloscope that will help me find the bad parts?
