Man you need to learn how to start that thing. Your starting procedure is way wrong.
And it shouldn't crank so slow the first couple of revolutions. After attempts, check if any cable ends are getting warm.
BTW, cold starting procedure:
1) Pump bulb until firm (hold motor end upward while pumping)
2) Lift fast idle to highest position
3) Turn key to 'on'
4) Press key in then turn to 'start' while holding key in (Primer is a valve and operates from fuel pressure pulses while motor is cranking. Dabbing the primer before cranking the motor does little or nothing)
5) Release key when the motor fires
6) Press key in if motor stumbles - should need shorter and less frequent presses as it warms
7) Lower idle lever as motor warms
