Johnson 90 VRO, 1986 compression values
scb2377
1986 Johnson 90hp VRO Oil injected 2 Stroke Outboard with a stainless prop.
Model # J90TL CD C
Motor is on boat and starts promptly, although not used on lake for 5-6 years.
Are these good compresison values?
111 110 113 110
Is the motor worth $1000?
Thanks. Cris
hoeser
Re: Johnson 90 VRO, 1986 compression values
Yep, pretty good indeed. If you buy the motor, replace the water impeller before any use. Also pull of and clean the carbs, and decarbon the engine. That's a nice engine. Oh and I don't know what they are worth money wise... $1000 seems good to me especially with a stainless prop and working VRO... but not sure, I'm just saying the compression values are good.
