johnson 90hp v4
bayliner1972
Now that the carbs on my motor are clean I still have trouble starting the engine. It will run for about 5 sec then cut off. This will repeat it self about 5 to 6 times before the engine will keep running. Reeldutch said to me something about my tstats remaining open.. What are tstats ???<br />Reeldutch are you still online ?? HELP
JB
Re: johnson 90hp v4
What year or model number is your engine, Kevin?<br /><br />Imperfect carb cleaning causes many problems, but I think your engine is running out of fuel or it needs additional priming/choking. <br /><br />You may have a failing fuel pump, too.<br /><br />Good luck. :)
bayliner1972
Re: johnson 90hp v4
the fuel pump works fine. I have also recleand the carbs today but this does not solve the problem
Cricket Too
Re: johnson 90hp v4
How are you cleaning them? Anything less than pulling them and soaking them, is not 100%.
bayliner1972
Re: johnson 90hp v4
I got myself a carb cleaner. This is a spraycan under very high pressure. I put the nozzel on all the injecters and pump them clean. Is this enough or should i do this with compressed air
reeldutch
Re: johnson 90hp v4
what starting procedure do you use?<br /><br />make shure bulp is nice and firm<br />put key in on position.<br />press the key in while holding it in turn to start.<br />release key when engene fires and when it stalls press key in for activating primer<br /><br />tell us how you do it.
bayliner1972
Re: johnson 90hp v4
Hey reeldutch.. <br />I do the exact things you mention.. I am getting really desperayte seeing that the weather here is going to be good this weekend and i want to take her out
bayliner1972
Re: johnson 90hp v4
Reeldutch,<br />Je had het ook over dat de stats mischien open blijven staan..waar zitten die in gods naam. wat is trouwens je email adres
Solittle
Re: johnson 90hp v4
When cleaning carbs you need to thoroughly blow them out with high pressure air from an air compressor. The spray can does not cut it.
