Well yesterday i spent some cash on parts.<br />I bought new prop, spark plugs, plug wires, fuel filter, fuel hose with primer bulb.<br />Installed everything fired her up. and engine had no spark on one cylinder. swaped cables with another clinder still no change. Swaped the Hi voltage pack with another cylinder and problem went away, all cylinders started firing. Have not swaped ignition coils back yet to see if problem comes back. I was going to try the 10watt 10ohm load test on the power pack tonight to see if the power pack is ok. I ohmed out the ignition coils and they appear to be fine.<br />Oh by the way i also purchased a manual.lol <br />Also noticed where the vro is mounted the ears are cracked, someone cranked on em a little tight.
