Johnson Alarm
Daniel Beckman
I got a Johnson 175 hp faststrike -93<br />The motor runs fine but when i running it at full speed it will after a little while start to beep (the alarm)<br />I think it´s wanna warn me for no oil, but the tank is full, and it beep a little random.<br />And its only beep when i got full speed, if i close down just a little it stop warning???<br />Can it be that the enginen doesnt get enough gas<br />Cause the alarm should beep countinusly when it warn for that... i mean is it maybe on the edge to to little gas???<br /><br />Thanks from Sweden
Pursuit2150
Re: Johnson Alarm
One cause for the alarm "May be" obstruction's in the fuel line. Dis-connect the lines, blow them out and see if that helps.
cddfamily
Re: Johnson Alarm
Daniel,<br /><br />I can't say for sure that the cause of your problem is the same, but I had the same symptoms on the same model and same year. <br /><br />I had bad gas + fuel stabilizer + storage = liquid jelly for fuel that clogged the the VRO pump and all of the fuel system. Whenever I went above 3/4 throttle, the alarm would sound the low oil warning. It took several attemps and the factory tech to debug and fix. All of the lines were replaced, carb jets cleaned, VRO replaced, internal lines replaced, etc. <br /><br />- check and clean fuel lines and tank pick-up<br />- check and clean fuel tank vent<br />- check and clean oil lines and tank pick-up<br />- change fuel filters<br />- drain and replace with new gas<br />- eventually my VRO pump failed due to the viscousity of the oil/fuel mix<br /><br />VRO CODE<br />continuous tone [all rpm] = overheat<br />continuous tone [~WOT] = fuel restrictions<br />continuous short tones = no oil<br />short tones every 40sec = low oil<br /><br />good luck - cliff
D
DJ
Guest
Re: Johnson Alarm
Daniel,<br /><br />Also not a bad idea to remove and clean the VRO tank. No one ever does this. <br /><br />Replace the pick up sock on the VRO pick up also.<br /><br />If you have not done this previously, I think you'll be surprised what is in there.
Daniel Beckman
Re: Johnson Alarm
I will try the tip you guys give me.<br /><br />Many thanks from Sweden.<br /><br />Daniel,
