Ok, So I have been reading so many different opinions on the noises and meanings of alarms.
I have a Johnson 175 hp 2-stroke (VRO non existent) 1988 motor.
Bfore today my rectifier was stuffed. if i knew what I knew then I would not of had my rectifier catch fire. The tach never worked from day one.
On day one the motor died in the harbour. Started every now and then and then died. thought i nriefly heard an alarm for a millasecond.
Anyway, mechanic replaced everything to do with fuel, said motor was getting too hot due to being filled up with salt. also fuel line hole was too thin.
I think i was runing out of fuel and that why motor kept dying.
Anyway, Day two and rectifier catches fire.
Day, three new rectifier put on and tach works, even though when it was put on it was also discovered that one out of the three pins in the plug running to the tach was not in its hole. So not sure if it did not work cause of rectifier or cause i plugged it in wrong or if it was always plugged in wrong.
Also at same time mechaninc unceases the timing advance.
So boat was running awesome today, amazingly fast and i am super happy with the motor. So happy i have put off buying a bigger, newer motor.
Then all the sudden i get this ALARM of a constant high pitch sound when at WOT.
I check petrol and it is more or less empty. I put more petrol in and dont hear the alarm again.
I have been reading that a constant alarm means that it is overheating. Today for me it meant low fuel.
What do all the alarms mean that i will ever be able to har come from my outboard so that I know what each one means when i hear each one.
Also, my tach is going way off the clock, it seems and my mechanic says that it is not set correctly. He saw it idling at 2000rpm, took it home and it idled at 1500 rpm and then in gear it idled at 1000rpm. I have a feeling he just saw it when it was playing up for that once. But he reackons my tach is not set properly.
My tach at WOT can go right off the clock. My clock stops at 6000, it looks lie it wants to go to 10,000.
He tells me i have a RPM limiter set for 5800. who knows if it works or not.
So my tachs are VDO, real old white ones that go up to 6000.
It has 8 dip switches on the back and a number that reads 209-B. I cant find anywhere to set this thing. the only ones on the site are 3 dip switches. I need to set it for 12 pulses so i am told. is this correct?
Anyway, that is about all of my problems i think.
I would appreciate loads of comments and stuff for me to learn from.
I have read every single thread in this forum after searching 1988 Johnson 175.
Please teach me more and please comment on my issues.
