I have a 2003 Johnson Bombadier 50 Hp Four-Stroke. I am converting it froma tiller handle to a consule drive. I got the wire harness I needed and the new control box. I got everything hooked up, but I have no warning horn. I tested the horn with 12-volts and it sounds but when I start the motor It does not do a 1/2 second beep. does anyone know if I could short out a overheat sensor to test? and where they are located? Any info will help.
