Blue Fin 135
- Joined
- Aug 20, 2010
- 16
Johnson Boys Need Your Help
Hey,
I have been boating for years, but started off and always had inboards. Got a great deal on a fishing boat with a 135 HP Powershift 2. Pulled it home put the muffs on it?would not go. Changed out the plugs, turned the key and it fired like a champ. Ran for a couple of minutes and I was keeping my eye on the exhaust to see the tell tale sign of water trickeling out?nothing. I shut down immediately.
Now here come the stupid questions
1) The water outlet on this motor should come out with the exhaust gas right?
2) I never let it run very long, no alarms sounded but the head was uncomfortably hot to the touch ( Did I not give it enough time)
3) Before I drop the bottom end and check the impeller on the pump I though of a fast test tell me if I am Right.
4) Look at the pic I attached. The two hoses that I point to in red. Are they the input hoses or the output hoses? Because I took one off and no water.
5) My thought is if they are the input hoses, (first pull the plug wires off and turn off the fuel) I could turn the water on the muffs Undo one of the hoses and turn the motor over. If water comes out?pump is working. If they are the output hoses then maybe thermostat? Please look at the pic and respond with any thoughts. Thank you in advance.
Hey,
