I have a 1982 Johnson 90hp v4 outboard. I recently re-built the carbs with Sierra carb re-build kits. I only replaced what came with the kit which I believe is just the standard stuff like gaskets and stuff. My main question is, I was wondering if a basic re-build will affect your idle or anyhting. Will I have to re-adjust anything or should it run the same. How do you adjust the idle on that carb?? Any help is appreciated.
