Johnson carb tweeking
Put a "New" 8 hp carb on and want to know what adjustments need to be done to provide max power. No top end power as of now. I have adjusted the "Low" speed jet on the right side of the carb. Where exactly is the "High" speed adjust?
Re: Johnson carb tweeking
Damn! I knew that was going to be the answer. Thought I was overlooking it.
Vic.S
I think you need to look carefully at the parts lists for the 6 and 8 hp engines to see if there are any differences that you have overlooked.
I know I cannot realistically convert my older 6 into a 8 by swapping carbs. I forget all the reasons now but it was inlet manifold, leafplate related maybe even porting. I am not saying it was impossible just not worth it.
EDIT:
The cylinder and crankcase assemblies are different part numbers for the 6 & 8 so there is a fundamental difference there somewhere. For you to go through the whole parts list for that group and find the differences.
