Still learning charging systems on outboards, but my understanding is that they aren't really meant to "Charge" a battery..
Rather, they're good for maintaining a charge on an already charged battery..
Sure, it'll charge it some, but I think it takes a LONG time to charge a battery back to full from that low..
It also depends on the battery condition.
I think I'd probably charge the battery on a house charger so it's fully charged that way, then get the battery load tested too just to be sure the battery is ok..
(EDIT: You may find that after charging at home, and load test shows ok, it may be fine after that with no more issue...)
If you're running a bunch of accessories off the same battery, then that will affect how well it charges from the engine as well..
While I don't have the info off the top of my head, I might also look up how to test my charging circuit from the engine to make sure it's really charging at all too.
If not, that'd be the first thing to fix..
I think anyway..
NOT an expert, but that's how I understand it at this point..
Hope it helps... At least a little..
